actually, what I wanted was when the PIC pin HIGH, then the LED array turn on, and the LED array must be using the same supply +5V as supplied to the PIC.
I thought of using LED driver to drive the LED arrays, where the input voltage to the LED driver is supplied by the PIC I/O pin. I wonder will this work. If so, what type of LED driver should I use?
do you want to light ALL 16 leds or turn of ALL 16 leds only?
do you plan to use the I/O pin of pic as a supply (VDD) to some part? if so - remember that ports can supply no more than 20mA, you should use a transistor to supply more.
i don't know much about led drivers, but those are usually just SIPO registers <:
if you plan just to turn the led array on or off, you should put a transistor at the common anode/cathode of the led array and that's all.
