Rizwanishaq
Junior Member level 3
74hc922
Can anyone help me connecting of the keypad to the 8051 and give the program
$NOPAGING
$MOD252
;Code: 4x4 matrix key pad
;Inputs: hex keypad via port1
;Outputs: ASCII value of pressed button is sent through the serial port and also the hex equivalent is ouput thru p3.5 to p3.2
ROW0 EQU P1.0
ROW1 EQU P1.1
ROW2 EQU P1.2
ROW3 EQU P1.3
CLMN0 EQU P1.7
CLMN1 EQU P1.6
CLMN2 EQU P1.5
CLMN3 EQU P1.4
DIGIT DATA 30h ;temporary storage of pressed key ..
ALERT EQU P3.7 ;goes low when any key's pressed ..
ORG 0000h
LJMP Ks_Main
ORG 0030h
;_________________________________________________________________
;----------SERIAL PORT INITIALISATION STARTS HERE-----------------
S9k_Main: MOV TMOD,#20h ;timer_0 in mode2 (8bit auto reload) ..
MOV TH1,#0fdh ;set baud to 9600 ..
MOV SCON,#50h ;serial mode1 (8bit data varialble baud) ..
SETB TR1 ;start timer_0 ..
RET
;--------------SERIAL TRANSMIT SUBROUTINE-------------------------
Tx_Main: MOV SBUF, A
Tx_Loop: JNB TI, Tx_Loop
CLR TI
RET
;--------------SERIAL RECIEVE SUBROUTINE--------------------------
Rx_Main: CLR A
Rx_Loop: JNB RI, Rx_Loop
MOV A, SBUF
CLR RI
RET
;----------------------20ms delay---------------------------------
Delay_20ms: ;PUSH R0
;PUSH R1
MOV R0, #36
Delay_20ms_Loop1: MOV R1, #255
Delay_20ms_Loop2: DJNZ R1, Delay_20ms_Loop2
DJNZ R0, Delay_20ms_Loop1
;POP R1
;POP R0
RET
;------------------------display subroutine--------------------------------
Disp_Message: PUSH ACC
Disp_M_Loop1: MOV A, #00h ; reset accumulator ..
MOVC A, @A+DPTR
CJNE A, #00h, Disp_M_Loop2
POP ACC
RET
Disp_M_Loop2: MOV SBUF, A
LCALL Tx_Main
INC DPTR
LJMP Disp_M_Loop1
Disp_Pressed: DB ' Key pressed is: ', 00h
;----------------packed ascii to hex conversion------------------
Ascii2hex: PUSH ACC
MOV A, DIGIT
SUBB A, #30h
MOV B, A
ANL A, #10h
CJNE A, #00h,Ascii2hex_Loop2
MOV B, A
Ascii2hex_Loop1: MOV DIGIT, A
POP ACC
RET
Ascii2hex_Loop2: MOV A, DIGIT
SUBB A, #37h
SJMP Ascii2hex_Loop1
;------------------send pressed button via p3----------------------
Send4x4_Parallel: PUSH ACC
MOV A, DIGIT
RRC A
MOV P3.5, C ; LSB ..
RRC A
MOV P3.4, C
RRC A
MOV P3.3, C
RRC A
MOV P3.2, C ; MSB ..
POP ACC
RET
;-------------------------main code------------------------------
Ks_Main: MOV P1, #0FFh ; Make input ports ..
;mov p3,#00h ;make output ports; never make this mistake => 3.0 n 3.1 are serial pins
SETB ALERT
LCALL S9k_Main
Ks_Main1: MOV P1, #0F0h ; all columns high n rows low ..
MOV A, P1
ANL A, #11110000b ; consider only columns ..
CJNE A, #11110000b, Ks_Main1 ; initially check for all keys released ..
Ks_Loop1: LCALL Delay_20ms
MOV A, P1
ANL A, #11110000b ; scan columns ..
CJNE A, #11110000b, Debounce ; if key pressed, check debounce ..
SJMP Ks_Loop1 ; if not, keep checking for key pressed ..
Debounce: LCALL Delay_20ms
MOV A, P1
ANL A, #11110000b
CJNE A, #11110000b,Check_Row
SJMP Ks_Loop1
Check_Row: MOV DPTR, #Disp_Pressed
LCALL Disp_Message
CLR ROW0
SETB ROW1
SETB ROW2
SETB ROW3
MOV A, P1
ANL A, #11111110b ; test row zero ..
CJNE A, #11111110b, Row_0
SETB ROW0
CLR ROW1
SETB ROW2
SETB ROW3
MOV A, P1
ANL A, #11111101b ; test row one ..
CJNE A, #11111101b, Row_1
SETB ROW0
SETB ROW1
CLR ROW2
SETB ROW3
MOV A, P1
ANL A, #11111011b ; test row two ..
CJNE A, #11111011b, Row_2
SETB ROW0
SETB ROW1
SETB ROW2
CLR ROW3
MOV A, P1
ANL A, #11110111b ; test row three ..
CJNE A, #11110111b, Row_3
SJMP Ks_Loop1
Row_0: MOV DPTR, #Disp_Kcode0
SJMP Find_Num
Row_1: MOV DPTR, #Disp_Kcode1
SJMP Find_Num
Row_2: MOV DPTR, #Disp_Kcode2
SJMP Find_Num
Row_3: MOV DPTR, #Disp_Kcode3
SJMP Find_Num
Find_Num: RLC A
JNC Found_Num ; which column is pressed/grounded ..
INC DPTR
SJMP Find_Num
Found_Num: CLR ALERT ; notify main MC that key has been pressed ..
CLR A
MOVC A, @A+DPTR
MOV DIGIT, A
LCALL Tx_Main ; send pressed button to serial port ..
LCALL Ascii2hex
LCALL Send4x4_Parallel
SETB ALERT ; bring keypad module to waiting state ..
LJMP Ks_Main1
Disp_Kcode0: DB '0','1','2','3'
Disp_Kcode1: DB '4','5','6','7'
Disp_Kcode2: DB '8','9','A','B'
Disp_Kcode3: DB 'C','D','E','F'
END
