hsiangleung
Junior Member level 2
In a differential pair amplifier, the vid is supposed to be much smaller than Vov so as to maintain a good linearity. But what i confused about is that the amp is always used in a closed loop, in which case the vid can be rather small because of the large gain( two input terminals almost ''short'') and as a result the linearity is indeed improved by use of feedback. So inpractice design, is it meaningful to set a large Vov to improve linearity? what do we usually do to improve lineary?
