code not working plz help
Kfir Maymon
Member level 1
Israel
hey im tring to resolve sothing plz help
this code is working great:
void init() {
ANSEL =0X00;
ADCON0= 0X00;
CMCON = 0X07;
TRISC=0x03 ;
TRISA=0xff;
PORTC=0x00;
int newread=0;
void main()
init();
while(1)
if(PORTA.F5==1)
PORTC.F3=1;
if(PORTA.F5==0)
PORTC.F3=0;
if(PORTA.F4==1)
PORTC.F4=1;
if(PORTA.F4==0)
PORTC.F4=0;
this is not way???
void init() {
ANSEL =0X00;
ADCON0= 0X00;
CMCON = 0X07;
TRISC=0x03 ;
TRISA=0xff;
PORTC=0x00;
int newread=0;
void main()
init();
while(1)
if(PORTA.F5==1 && PORTA.F4==1)
PORTC.F3=1;
if(PORTA.F5==0 && PORTA.F4==0)
PORTC.F3=0;
im useing royary encoder as a switch and osilloscope to monitor the two ch so i know they going high and low
what is the error message that you are getting ?
try like this sometimes it could solve the issue. if((PORTA.F5==1) && (PORTA.F4==1))
Are you trying to reduce your number out output ports? In the first code youa re using F3 and F4 and the second one you are using one. I am just making sure that was the intention. Another problem is that if the stimulus is fast enough, both if statements could execute in one cycle which makes the port the 2nd state. You should do some type of delay function between reads.
Im thing to operate a rotary encoder and something want worng, so i try to debug it, and this is what i got.
I don't get any errors code but on the bord it doesn't working.
Wean i get home i will try this if((PORTA.F5==1) && (PORTA.F4==1))
And give you a feedback tnx
In mikroC code you have to do like this...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
if((PORTA.F5 == 1) && (PORTA.F4 == 1))
    PORTC.F3 = 1;
if((PORTA.F5 == 0) && (PORTA.F4 == 0))
    PORTC.F3 = 0;
//or
if((PORTA.F5) && (PORTA.F4))
    PORTC.F3 = 1;
if((!PORTA.F5) && (!PORTA.F4))
    PORTC.F3 = 0;
//or
if((PORTA & 0x30) == 0x30)
    PORTC.F3 = 1;
if((PORTA & 0x30) == 0x00)
    PORTC.F3 = 0;
//or
    PORTC.F3 = 1;
if(!(PORTA & 0x30))
    PORTC.F3 = 0;
If RA4 and RA5 are connected to buttons then you need to debounce like this...
Code C - [expand]
    Delay_ms(50);
    if((PORTA.F5 == 1) && (PORTA.F4 == 1)) {
        PORTC.F3 = 1;
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
    PORTC.F3 = 1;
    PORTC.F3 = 0;
//or
    PORTC.F3 = 1;
    PORTC.F3 = 0;
//or
    PORTC.F3 = 1;
    PORTC.F3 = 0;
//or
    PORTC.F3 = 1;
if(!(PORTA & 0x30))
    PORTC.F3 = 0;
Code C - [expand]
    Delay_ms(50);
        PORTC.F3 = 1;
tnx its was very helpfall
