cmdmprobe, why there is netlist problem when i use it
jingxuelu
Junior Member level 3
cmdmprobe
I'm trying to use cmdmprobe to check the stability of my gain boosting opamp, but after i added it, i found i cann't start to simulate the circuit.
The simulation log outputs:
ERROR (OSSHNL-318): Unable to determine switch master for instance 'evinj' in cell 'cmdmprobe'. Examine your
switch view list and design/reference libraries to ensure that this instance is
bound to a master view and netlist again.
End netlisting Sep 16 16:25:12 2008
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may be corrupt
or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
...unsuccessful.
Is there anyone can give me some advice how to use cmdmprobe, thanks so much!
stability -probe instance cmdmprobe
It seems to me that the instance has no view in the required net listing format. Open the library manager and check that it has the Spetre or Hspice view. If not try to create one.
osshnl netlist error
i will try, thanks
