Clock in spi and i2c
Jinzpaul4u
Full Member level 4
India
Hi there,
good wishes.
Do anybody have an idea about,what is the difference in the clock line of spi and i2c protocols ??
Thanks in Advance
I'm really sorry for the confusion,
In the initial state of i2c,both clock and data lines are in high impedance state or kept as high after data trasmission.Again it goes to idle state.
but i found a small difference in the spi clock.As far as i know, the initial stage clock become low state,correct me if i'm wrong.
so do anybody have an idea about,what is the difference in the clock line of spi and i2c protocols ??
wireless microchip board apps note
  • 70650A.pdf
  • microchip demo board.pdf
wireless transmission spi based ic some useful app notes from microchip
  • MRF49XA (1).7z
  • pic18 main datasheet.pdf
  • mreaxa.pdf
  • main pic18.pdf
  • 01252A (1).pdf
  • 70650A.pdf
The SPI clock can idle in the high state or the low state depending on the mode selected. Find a mode that matches the part you are interfacing to and check the documentation for the processor you are using on how to set the compatible mode.
I wish to thank you for your invaluable support...
