viviadam
What can be done to avoid clipping on the positive side. Vdd is at 3.3 and VSS is at 0. I am giving an 8mv differential sine wave at the input. The common mode voltage (vref) is 1.5.
My design requires me to keep the lowest voltage at 0 and highest at 3.3. I want to amplify a small differential signal (common mode at roughly halfway between the supply and the ground) and maintain the same common-mode at the output. The differential signal is getting amplified properly for the negative half but gets clipped at the positive half. what device parameter has to be changed to try and reduce the clipping?Try making the bottom supply rail a negative polarity whose amplitude is same as your positive supply. Adjust bias values to bring your output waveform down so it's centered on 0V.
Speaking of bias it's usual to build a simpler bias arrangement which has fewer wires running to and fro.
I have checked the operating points. The top PMOS transistors have enough headroom to stay in saturation yet still somehow the waveform is getting clipped.You can annotate DC operating point and node voltages to debug by looking what is the status of all transistors.
