Clipping in differential amplifier with common mode feedback
viviadam
What can be done to avoid clipping on the positive side. Vdd is at 3.3 and VSS is at 0. I am giving an 8mv differential sine wave at the input. The common mode voltage (vref) is 1.5.
Your negative images were so black and with the parts so far apart that it was difficult to see the text.
So I inverted it to make it a normal positive image then I cropped and enlarged it so it is large enough to read the text.
You can annotate DC operating point and node voltages to debug by looking what is the status of all transistors.
Try making the bottom supply rail a negative polarity whose amplitude is same as your positive supply. Adjust bias values to bring your output waveform down so it's centered on 0V.
Speaking of bias it's usual to build a simpler bias arrangement which has fewer wires running to and fro.
My design requires me to keep the lowest voltage at 0 and highest at 3.3. I want to amplify a small differential signal (common mode at roughly halfway between the supply and the ground) and maintain the same common-mode at the output. The differential signal is getting amplified properly for the negative half but gets clipped at the positive half. what device parameter has to be changed to try and reduce the clipping?
I have checked the operating points. The top PMOS transistors have enough headroom to stay in saturation yet still somehow the waveform is getting clipped.
What happens if you replace the CMFB block with a voltage source?
I believe you need to add more DC component to your incoming AC signal. That should shift circuit behavior midway between supply and ground. (The arrangement is similar to a class A amplifier.) As you adjust the signal up or down, you should be able to position the output so the entire waveform is visible with no clipping.
The principle becomes obvious if you experiment with a simple class A amplifier and oscilloscope.
