vink
Newbie level 3
Hi all,
I faced this problem while designing strutures on a CPW line using IE3D. The manual claims that the accuracy of simulations will be very good if its about 20cells per wavelength. I started at 15cells/λ to 50. But with every simulation i was getting different results, S-parameters were not converging. WHich results should i take as most accurate. One point i would like to mention is i was interested in 1-5GHz and the structure was 2mm x 4.5 mm, (very small than λ).
Thanks in Advance
Thanks in Advance
