neazoi
Advanced Member level 6
Hi, in a hypothetical simple BJT pair multivibrator operating in the 500KHz region (RF), each output (BJT collector) swings between VCC and ground (or at least near).
So the output signal read on a scope, would be a square wave, with the lower end at 0v and the higher end at 5v.
Now what will happen if I connect a capacitor between the collector and the scope probe, and connect the ground lead of the probe to the ground?
What will be the signal read on the scope?
Will this be the same waveform, with the lower end to zero volts and the higher end to 5v?
In your answer, assume that the capacitor is large enough in value to let the 500KHz pass through.
