Can I get the output impedance of OPAMP by hspice simulation
incol
Full Member level 2
How to simulate the output impedance?
Thanks!
Re: Can I get the output impedance of OPAMP by hspice simula
There is nothing to do with code. If you see into the output listing file .ls then you will be probably find out the value of output resistance. Value of input and output resistance will be given probably.
If I am wrong then please let me know. Because I am not in touch of these thing now a days.
Thanks!
I'll attach a very short summery of hspice for you. The colour of the part that you need was changed to red.
Hope it helps!!!
Thanks for your post!
Hope it helps!!!
Hi Sadegh.j,
I have read the file which you attach, form this file, I think it may be use ".print AC Zout(M)" to simulate output impedance, but if that so, I have two questions:
1. I didn't write output node, how does it know which node is the Zout.
2. How to add the AC source, add it to the input? or VCC?
thanks!
you need use .net to declarating the input port and output port, as following:
.net output input
the 'output' is the output voltage or output current you want to probe,
the 'input' is the input voltage or current source thate include 'ac='.
I think using the output voltage divided by the current is a basic method!
you can write some hspice command or calculate the output impedance based on gain and gm.
HI, can u give me some examples?
BTB, can i write some command in hspice scripts to do some integration & differentiation???? If i can, show me how to do this,
TIA,
use the ".tf" statement to solve the problem
Hi, everybody
Thanks for your advice, as to the TF command, i tried to use it and got a zero value, I guess what TF does is that at every DC point, it measures the DC voltage and DC current , and then compute the DC output impedance..
