Can I get a delay of one nano second?
Re: delay of nano second
Using a micro controller or circuits? Please elaborate your problem..
ssss959 said:
is it possible to get nano second delay
please post your question in detail..
thank you
i am doing a project
i want nano second delay
how is it possible
15 or 20 cm of coax cable or PCB trace has about 1ns of delay.
if i want 20 or 30 nano second delay
what should i do, i cannot take 150cm cable
any code for it
Maybe you could use a delay line component. They usually come in an ordinary DIP or SMD package. Search Google for various manufacturers. Here's one:
https://www.datadelay.com/
What do you mean by "code"? Computer program code or HDL code?
i want the program code
We can't give you program code when you do not tell us what you are using. Tell us everything, then tell more. Maybe we can help.
i am doing a project in mfrc500 reader
i want to comminicate between controller and mfrc500
so want nano second delay
Tell us the clock frequency of your controller. Expecting "code" for 1ns delay, your controller must be running on 10GHz.
i am using 10Mhz crystal
I think, you do not need this delay at all.
May be you want 1us delay?
I am doing a project in mfrc500 reader i want to comminicate between controller and mfrc500 so want nano second delay
I think, it's basically a misunderstanding. MF RC500 has a common peripheral interface. Shouldn't need a particular delay here. In some cases, processor bus parameters may need adjusting, but a delay is rather unlikely. What's your processor and why do you think needing a delay?
