true_niea
Newbie level 3
hai
hello could anyone can help me with this coding... im doing my mini project.. but the problem is after write the vhdl code for calculator coding show no prob but when i try to simulate show no output
here i attach the coding
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity calculator is port(A,B : in integer range 0 to 7; clk : in bit; sel : in std_logic_vector(1 downto 0); Q : out bit_vector(6 downto 0); An : out bit_vector(3 downto 0)); end calculator; architecture Behavioral of calculator is signal sub : integer range 0 to 7; signal sum : integer range 0 to 14; signal div : integer range 0 to 7; signal Mul : integer range 0 to 49; signal Qsub,Qsum1,Qsum2,Qmul,Qmul2,Qdiv :bit_vector(6 downto 0); signal minus : bit_vector(6 downto 0); signal divRemainder:bit_vector(6 downto 0); signal B1:bit_vector(6 downto 0); signal clk1: bit; begin clkDiv : process variable count :integer range 0 to 50000000; begin wait until clk'event and clk='1'; count := count + 1; if (count = 50000000) then count := 0; elsif (count < 25000000) then clk1 <= '0'; elsif (count > 25000000) then clk1 <= '1'; end if; end process clkDiv; sub_opration : process(A,B) begin if(A>B) then sub<=A-B; minus<="1111111"; case sub is when 0 =>Qsub <="1000000"; when 1 =>Qsub<="1111001"; when 2 =>Qsub<="0100100"; when 3 =>Qsub<="0110000"; when 4 =>Qsub<="0011001"; when 5 =>Qsub<="0010010"; when 6 =>Qsub<="0000010"; when 7 =>Qsub<="1011000"; when others => null; end case; else sub<=B-A; minus<="0111111"; case sub is when 0 =>Qsub<="1000000"; when 1 =>Qsub<="1111001"; when 2 =>Qsub<="0100100"; when 3 =>Qsub<="0110000"; when 4 =>Qsub<="0011001"; when 5 =>Qsub<="0010010"; when 6 =>Qsub<="0000010"; when 7 =>Qsub<="1011000"; when others => null; end case; end if; end process sub_opration; sum_opration : process(A,B) begin sum<=A+B; case sum is when 0 =>Qsum1<="1000000"; Qsum2<="1111111"; when 1 =>Qsum1<="1111001"; Qsum2<="1111111"; when 2 =>Qsum1<="0100100"; Qsum2<="1111111"; when 3 =>Qsum1<="0110000"; Qsum2<="1111111"; when 4 =>Qsum1<="0011001"; Qsum2<="1111111"; when 5 =>Qsum1<="0010010"; Qsum2<="1111111"; when 6 =>Qsum1<="0000010"; Qsum2<="1111111"; when 7 =>Qsum1<="1011000"; Qsum2<="1111111"; when 8 =>Qsum1<="0000000"; Qsum2<="1111111"; when 9 =>Qsum1<="0010000"; Qsum2<="1111111"; when 10=>Qsum1<="1000000"; Qsum2<="1111001"; when 11=>Qsum1<="1111001"; Qsum2<="1111001"; when 12=>Qsum1<="0100100"; Qsum2<="1111001"; when 13=>Qsum1<="0110000"; Qsum2<="1111001"; when 14=>Qsum1<="0011001"; Qsum2<="1111001"; when others => null; end case; end process sum_opration; Mul_operation : process(A,B) variable Remm10:integer range 0 to 9; variable C1: integer range 1 to 7 :=7; begin Mul<= A*B; if(Mul<10) then case Mul is when 0 =>Qmul<="1000000"; Qmul2<="1111111"; when 1 =>Qmul<="1111001"; Qmul2<="1111111"; when 2 =>Qmul<="0100100"; Qmul2<="1111111"; when 3 =>Qmul<="0110000"; Qmul2<="1111111"; when 4 =>Qmul<="0011001"; Qmul2<="1111111"; when 5 =>Qmul<="0010010"; Qmul2<="1111111"; when 6 =>Qmul<="0000010"; Qmul2<="1111111"; when 7 =>Qmul<="1011000"; Qmul2<="1111111"; when 8 =>Qmul<="0000000"; Qmul2<="1111001"; when 9 =>Qmul<="0010000"; Qmul2<="1111111"; when others => null; end case; else for j in 7 downto 1 loop if(10*C1<Mul or 10*C1= Mul)then Mul<=10*C1; Remm10:=10*C1-Mul; end if; C1:=C1-1; end loop; case Mul is when 0 =>Qmul2<="1000000"; when 1 =>Qmul2<="1111001"; when 2 =>Qmul2<="0100100"; when 3 =>Qmul2<="0110000"; when 4 =>Qmul2<="0011001"; when 5 =>Qmul2<="0010010"; when 6 =>Qmul2<="0000010"; when 7 =>Qmul2<="1011000"; when 8 =>Qmul2<="0000000"; when 9 =>Qmul2<="0010000"; when others => null; end case; case Remm10 is when 0 =>Qmul<="1000000"; when 1 =>Qmul<="1111001"; when 2 =>Qmul<="0100100"; when 3 =>Qmul<="0110000"; when 4 =>Qmul<="0011001"; when 5 =>Qmul<="0010010"; when 6 =>Qmul<="0000010"; when 7 =>Qmul<="1011000"; when 8 =>Qmul<="0000000"; when 9 =>Qmul<="0010000"; when others => null; end case; end if; end process Mul_operation; div_operation: process(A,B) variable C : integer range 1 to 7 :=7; variable Remm:integer range 0 to 9; begin for I in 7 downto 1 loop if(A=B)then div<=1; Remm:=0; elsif(B>A)then div<=0; elsif(A>B)then if(B*C<A)then div<=B*C; Remm:=B*C-A; --the result will display as: div _| Remainder _| B end if; C:=C-1; end if; end loop; case div is when 0 =>Qdiv<="1000000"; when 1 =>Qdiv<="1111001"; when 2 =>Qdiv<="0100100"; when 3 =>Qdiv<="0110000"; when 4 =>Qdiv<="0011001"; when 5 =>Qdiv<="0010010"; when 6 =>Qdiv<="0000010"; when 7 =>Qdiv<="1011000"; when others => null; end case; case Remm is when 0 =>divRemainder<="1000000"; when 1 =>divRemainder<="1111001"; when 2 =>divRemainder<="0100100"; when 3 =>divRemainder<="0110000"; when 4 =>divRemainder<="0011001"; when 5 =>divRemainder<="0010010"; when 6 =>divRemainder<="0000010"; when 7 =>divRemainder<="1011000"; when others => null; end case; case B is when 0 =>B1<="1000000"; when 1 =>B1<="1111001"; when 2 =>B1<="0100100"; when 3 =>B1<="0110000"; when 4 =>B1<="0011001"; when 5 =>B1<="0010010"; when 6 =>B1<="0000010"; when 7 =>B1<="1011000"; when others => null; end case; end process div_operation; choice : process(clk1,sel) variable m : integer range 0 to 3 := 0; begin if(clk1'event and clk1 = '1') then case m is when 0 => if(sel = "00") then Q <= Qsub; elsif(sel="01") then Q<=Qsum1; elsif(sel="10") then Q<=Qmul; elsif(sel="11") then Q<=B1; end if; An<="1110"; when 1 => if(sel = "00") then Q <= minus; elsif(sel="01") then Q<=Qsum2; elsif(sel="10") then Q<=Qmul2; elsif(sel="11") then Q<="1110011"; -- display _| end if; An<="1101"; when 2 => if(sel="11") then Q<= divRemainder; end if; An<="1011"; when 3 => if (sel="11") then Q<= Qdiv; end if; An<="0111"; end case; m := m + 1; end if; end process choice; end Behavioral;
