Drago
Member level 3
dsp/bios bootloader
Does anybody of you have a C6711 DSP/BIOS Bootloader project? I’ve try to make it hundred of times but without success. After reading the TI’s PDF I wrote the bootloader without DSP/BIOS and it is running ok. Unfortunately it is not the same with the BIOS version.
The first 1k are well copied into the internal ram. The copy table Is read properly and all sections are placed where they have to be. But when I jump to the entry point …. the LEDs are not flashing. If I reset the DSP from the CCS menu and then load the OUT file they are flashing …
Any advices ????
I would be very thankful if you can send me some example project that is really working (on the 6711DSK or any other 6711 board)!
Thanks in advance,
Drago
P.S. there are some sections that are excluded from the HEX file, since it is in runtime autoinit:
-boot
-bootorg 0x90000400
-bootsection .boot_load 0x90000000
-exclude .sts
-exclude .log
-exclude .args
-exclude .LOG_system$buf
-exclude .LOG_MW1$buf
-exclude .stack
-exclude .logTrace$buf
Any advices ????
Thanks in advance,
Drago
-boot
-bootorg 0x90000400
-exclude .sts
-exclude .log
-exclude .args
-exclude .stack
