building lm2596 dc dc using Arduino uno
johnny78
Full Member level 4
hi Guys
i need to use an MCU as a voltage regulator
read about pwm & checked for some projects on the net
would you check this please ?
first i think the mosfet is connected wrong way (or im wrong) ?
after correcting the connection(S is the input & D is the output) & upladed the simple pwm code to my UNO
& build the citcuit on 3A dc dc buck conveter which i have removed the lm2596 & connected the IRF4509 on it
but it didt work as a regulator
& tried to drive the mosfet with arduino uno with this code
 * This is an example code for a BUCK converter circuit made with arduino
 * I've used arduino NANO. We have to set the timer of the PWM on pin D3
 * No feedback is connected here
 * Subscribe: http://www.youtube.com/c/electronoobs
 * webpage: http://www.electronoobs.com/eng_circuitos_tut10.php
int potentiometer = A0; //From the main potentiometer
int PWM = 3;
void setup() {
  pinMode(potentiometer, INPUT);
  pinMode(PWM, OUTPUT);
  TCCR2B = TCCR2B & B11111000 | B00000001;    // pin 3 and 11 PWM frequency of 31372.55 Hz
void loop() {
  float voltage = analogRead(potentiometer);
  int VALUE = map(voltage,0,1024,0,254);
  analogWrite(PWM,VALUE);
I would guess the inductor is marked 470 meaning 47 * 10^0 or 47uH.
You must understand the principle of using PWM is that the voltage is recovered from the average of the waveform and adjusting the on to off ratio directly controls the average but in the case of a voltage regulator the situation is a little different, you are controlling stored energy in the inductor. Also understand that the real LM2596 uses a bipolar series switch, not a MOSFET and the drive requirements are quite different between them, in particular the voltage needed between the output and base/gate which depends on what the actual output voltage is and the speed at which they allow their base/gate to change for a given drive current.
You need to understand that your circuit has a completely different behaviour than a true LM2596 circuit.
* different frequency
* different turn OFF timing
* feedbacked vs non feedbacked ...
* different part values
* different reaction time
* analog vs digital
* and so on
so you simply can´t compare it with a true LM2596 circuit.
The impact of "non feedbacked" vs "feedbacked" is like you want to compare an escalator to a car.
The escalator is non feedbacked, always the same speed, doesn´t care about load.
Where with a car you continously have to adjust speed..
yes thanks its 47uH
* analog vs digital
* and so on
i got it
trying this circuit is just for testing the voltage regulating method not to build an lm2596
but im using already parts on the lm2596 3A dc dc converter in case im just testing to build something can control the voltage
thanks
Johnny
If you want this, then you need to do this. Regulating. With feedback. And you will see a totally different behavoir.
Read your headline ;-)
If you want simple PWM control (without feedback) then use a halfbridge instead of a high side MOSFET.
