SR19
Junior Member level 3
Hi all,
I have attached the unipolar stepper Motor datasheet (which im using as bipolar) & Driver schematic .Step input is applied by using function generator.I need to drive this motor @ 1000 PPS for 300 RPM...but motor is running smoothly between 400 - 500Hz step input ..after this range motor starts vibrate..how can i make this motor will run smoothly @1000pps..
Thanks in advance
Thanks in advance
