[bc558] data sheet help
ardwinoman
hello ,please what diffrernce between collector current(DC) =-100 & peak collector current =-200 in limiting values table in data sheet attached .
is the first one dc and the second is ac or what ??
  • BC558.pdf
Re: dataaa sheet help?????
DC current means continuous or RMS (Irms=Ipeak*SQRT(DutyCycle)), while Ipeak means instantaneous e.g. during pulsed operation (Duty Cycle != 100%).
The graphs of its DC current gain shows that it works very well to 10mA and poorly above 60mA. I would use it to 50mA. A BC327 has the same case but a max continuous current of 800mA. I would use a BC327 to 300mA. Beware that if it is linear with voltage across it and a high current then it will overheat.
