holmesat21
Newbie
I made a BC109C circuit on spice that runs but my physical design doesn’t run. I was wondering if anyone sees an issue with this design I have shown.
They’re hand wound inductors. I chose .507 as it was just the easiest to wind. I knew it had something to do with the tank but really just wanted help in case it’s the biasing or something dumb like thatUnusual low LC circuit impedance. How did you arrive at the LC values?
Did you assign series resistance to model Q values according to inductor datasheet in your simulation?
With spice you still get the oscillation with the given values but they’re at the desired frequency (1MHz) I can try this solution to see if it works but it would take some time to wind that inductor and ultimately it wouldn’t be what I want it at.I think you have a bunch of an unused 100nF capacitors in your drawer...
Replace L7 with 5uH, and R3 with 1.5k, and you will get the oscillation.
