Vlad.
Full Member level 3
- Joined
- Jun 4, 2012
- Messages
- 179
- Helped
- 3
- Reputation
- 6
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Bucharest/Romania
- Activity points
- 2,568
Hi there,
I need to convert (Upsizing and Downsizing) two AXi 4 Stream Slave and Master. Hence, I want to do the following:
-from 1 byte AXI4 Stream Slave to 50 bytes width;
-from 1 byte AXI4 Stream Master to 4 bytes width
Please note that the 1 byte AXI4 Streams both slave and master are the outputs of an MII ethernet core which runs with 25 MHz, and have only data, ready and valid signals.
I have already used this core. the data width convert, but I have some questions:
1. is this the correct approach to do this task?
2. If the MII runs at 25 MHz, the AXI Data width converter IPs, should run also at 25 MHz?
Thank you,
Vlad
Thank you,
Vlad
