AWR Design load impedance(imaginary) promblem
ultralsj
Newbie
I want to calculate the v,i value with the port impedance as R+jX.
when the impedance of Port 2 was 50 ohm, V, I simulation is correct.
but when the impedance of port 2 was imaginary, V & i value is not correct
How should I apply the imaginary impedance of the load?
Because the syntax is not correct for the Port.
The right syntax must be Z=15-j*140. ( "i" has no meaning at all , EE uses always "j" instead of ))
