ATTINY 2313 programmer
isp attiny
Look here: **broken link removed**
AT90S2313 and ATTiny2313 , ISP programmer.
how to program attiny
yes, I have now sucessfully programmed the ATtiny2313.
The factory provides this chip such that NO EXTERNAL crystal
oscillator is required (an internal clock is used instead). I didn't
know this on the first instance and took me sometime to figure
out what's happening with the clocking. The older brother AT90S2313
was functioning differently as far as clocking is concerned.
I properly modified the fuse bits (CKSEL3,2,1) using PonyProg,
and the chip is now clocked from the external crystal (1 crystal,
2 capacitors, as mentioned in the data sheet).
I am using the chip in a kit which controls 8 relays through a
telephone line (still working on this).
    pasicr
attiny2313 projects
Hi Cplia,
What kind of programmer you use?
Can you explaine precisly setting for fuse bit,
I need to programm attiny2313 at 20MHz with crystal, projects is rgb generator for testing monitors,
regards
attiny2313 programmer isp
pasicr said:
Hi Cplia,
regards
I use PonyProg. The circuit I am using is the one that electronicus
mentioned above on this topic.
Since you want to clock your chip with a 20MHz crystal, then you need
to set CKSEL1=1, CKSEL2=1 and CKSEL3=1 (1 means unprogrammed,
as indicated in the data sheet for ATtiny2313, page.26). Fuses, determine the mode
of operation for the chip, e.g. to use internal instead of external clock, etc.
I guess an expert programmer can explain this with a better way.
good luck
attiny2313 circuit
cplia said:
pasicr said:
Hi Cplia,
regards
good luck
Electronicus has mentioned more than one circuit. Which one do you refer to ?
Thansks :D
como programar atmel attiny2313
wingsnow said:
cplia said:
pasicr said:
Hi Cplia,
regards
good luck
Thansks :D
this one (see attachment): enjoy
programing attiny2313
This is the one Im looking for. (with max232)
Which software program will support this programmer ?
Thanks.
attiny2313 programer circuits
Thanks.
2313 programer
Thanks.
IC-Prog 1.05D does not support ATtiny2313 :cry:
at 2313 programmer
im doing my project regarding scrolling message display comprising 7*50 arrays of LEDs.I have the program/code to display and scroll alphanumeric set of characters.
Here is the Hex code you need to burn into your ATtiny2313 microcontroller:
:100000000AC022C021C020C02BC01EC01DC074C0A9
:100010001BC01AC019C011241FBECFEDCDBF10E008
:10002000A0E6B0E0E0E6F7E003C0C89531960D9297
:10003000A436B107D1F710E0A4E6B0E001C01D92EC
:10004000A33CB107E1F7B4C2DBCF982F21E08BB11D
:1000500082958695877081708217C9F79CB908953B
:100060001F920F920FB60F9211242F933F934F932D
:100070005F936F937F938F939F93AF93BF93EF9310
:10008000FF93809169008250823030F490916C002F
:1000900084E1891BDADF1FC080916F008823DCF0C8
:1000A000809170008F5F8093700080917000883322
:1000B00010F010927000809163008F5F8093630056
:1000C00080916300883310F01092630080916F007C
:1000D000815080936F00FF91EF91BF91AF919F91FD
:1000E0008F917F916F915F914F913F912F910F90E1
:1000F0000FBE0F901F9018951F920F920FB60F9280
:1001000011248F93EF93FF9380916C00843111F44D
:100110008CB118C080916D00E82FFF27E155FF4F8B
:100120008CB1808380916D008F5F80936D00809192
:100130006D00843111F410926D0080916C008F5F1E
:1001400080936C00FF91EF918F910F900FBE0F90F5
:100150001F90189580916C008823A1F080916E000B
:10016000E82FFF27E155FF4F8F5F80936E00E081FE
:10017000843111F410926E0080916C008150809354
:100180006C008E2F0895089590E080E08F5F8F3F80
:10019000E9F79F5F9236C8F308951F93DBDF8091E4
:1001A0006C008823E1F3D6DF982F8D3DB1F18E3DB1
:1001B00018F48823A1F045C08D3F19F08E3FD9F087
:1001C00040C0809169008093680084E0809369005A
:1001D00080E03BDF10926A0010926B0032C0809189
:1001E00069008093680082E08093690090936A00C0
:1001F00090936B0026C0809169008093680015E0A1
:10020000109369008DED21DF10936A0083E08093E5
:100210006B008FEF8093670014C08091690080931A
:10022000680093E09093690085E080936A00909362
:100230006B008BEF94E090936600809365001092C2
:1002400064001F91089589E00000815087FFFCCF72
:1002500008951F93CF9314E0C1E0959A959888B3C1
:100260008C2B88BB112309F412E0F89420917000C4
:10027000283308F020E0E22FFF27E958FF4F808164
:10028000812309F0929A949A94989298922F2F5FD2
:1002900080916300981761F77894110F9C2F9095C7
:1002A00088B3892388BBCFDFCC0FC7FFD6CFCF91D0
:1002B0001F91089591E080E0392F292F2670E82FB3
:1002C000FF27990F8F5F222321F0EF58FF4F3083D4
:1002D00003C0EF58FF4F2083863078F3089530E055
:1002E00091E0E1E7F0E024E0819180FD392B990F66
:1002F000215027FFF9CF373008F036E090916300A6
:100300009F5F332379F0A1E7B0E0232F983308F003
:1003100090E0E92FFF27E958FF4F8D9180839F5F81
:100320002150A1F7832F0895000000000000000075
:100330000895BF980895BF9A0895C79AF5DF089564
:10034000C798F2DF0895969AEFDF08959698ECDF4C
:100350000895F3DFF8DFF4DFF9DF0895F4DFEDDF70
:10036000F5DFEEDF08951F93CF93E3DFC79A10E028
:10037000C0E8E9DFB7991C2BE9DFC695D1F7DBDFD1
:10038000C798812FCF911F9108951F93CF93182F56
:10039000C0E8812F8C2311F0D0DF01C0D1DFD3DF83
:1003A000D5DFC695B1F7C5DFC8DFCDDF8FEFB799D1
:1003B00005C0C798C0DFCADF80E006C08150B9F72A
:1003C000C5DFBEDFB8DF81E0CF911F910895CF93E5
:1003D000C62F8093610060936000880F806AD5DF2C
:1003E000882319F48C2FD1DF811181E0CF910895FA
:1003F0000F931F93CF93C82F062F142FAADF612FBF
:10040000802FE5DF882329F48C2FBFDF182F882366
:1004100011F081E008C0A2DF809160008F5F8093BF
:100420006000B2DE812FCF911F910F9108951F932D
:10043000CF93C82F162F80916100C81721F48091A7
:100440006000681731F085DF612F8C2FC0DF8823B3
:1004500039F47FDFCC0F8C2F816A97DF882311F06E
:1004600080E014C080DFC82F79DF909160009F5F2B
:1004700090936000992349F4809161008F5F80938D
:100480006100883010F0909361008C2FCF911F9104
:100490000895EF92FF920F931F93CF939927282FE0
:1004A000392F220F331F220F331F280F391F832F9D
:1004B0009927182F1D5FC22F81E7E82E80E0F82EC4
:1004C00004E06C2F812FB3DFFF2DEE2D8193EE2EF4
:1004D000FF2ECF5F09F41F5F015007FFF2CFCF91CE
:1004E0001F910F91FF90EF900895CF93E3DE8091DD
:1004F0006900823008F054C0C0916C00CC2361F5D3
:1005000084E1A3DD80916900882319F58091620060
:100510008F5F809362008B3008F442C084E1809347
:10052000620060916A0080916B0081DF882319F47A
:1005300080936A000BC0ADDF80916A008F5F80936B
:100540006A00882369F580916B008F5F80936B0050
:1005500027C0C093620024C090916C0084E1891B85
:1005600074DD80916E00E82FFF27E155FF4F8081F9
:100570008F3F11F412DE14C0809162008B3020F0A6
:100580008150809362000CC0E5DD882319F08F3F15
:1005900009F07FDF1092620010926A0010926B00E7
:1005A0009EDE90916F00980F90936F00CF91089509
:1005B000CFEDD0E0DEBFCDBFE7E7F0E087E31192FB
:1005C000815087FFFCCF18BA12BA8FEF87BB81BB6F
:1005D00090E499BF8CE08EBD84E08BBD1ABC88E9A5
:1005E0008AB999B97894809169008430E9F45D9B67
:1005F000B0C090E080916B00833020F460916A007D
:1006000016DF982F9CB9992309F45BC080916A008A
:100610008F5F80936A00882309F09BC080916B00F4
:100620008F5F80936B0095C0823059F580916C008C
:100630008823E1F38FDDC82F60916B00633039F0C0
:1006400040916A00D5DE882311F4CC2369F410921E
:100650006A0010926B00809168008093690081307D
:10066000D1F11092620075C080916A008F5F809313
:100670006A008823D9F680916B008F5F80936B00AE
:10068000D5CF853061F5C4E060916A0080916B0040
:10069000CEDEDBDC80916A008F5F80936A00882366
:1006A00029F480916B008F5F80936B00C150C7FF6E
:1006B000EBCF90916700915090936700992309F0D8
:1006C00048C090936A0090936B008091680080937B
:1006D00069008130C9F584E1809362003AC08330BB
:1006E000C1F580916C00882339F134DD40916A00B6
:1006F00060916B007DDE282F882359F4809165007E
:100700009091660001979093660080936500892B15
:1007100021F48FEF80936400E4CF80916A008F5FB3
:1007200080936A00882329F480916B008F5F809307
:100730006B0020936400D5CF909164009F5F9093ED
:100740006400992321F4BDCF9093620002C01CDDA8
:10075000C8CF7FDD80916F0087FF45CFC6DE43CFD6
:04076000FFFF0A315C
:00000001FF
My project is consist of 256 characters with ATtiny2313 microcontroller. It uses seven BD139 and 74HC595 as a LED driver and shift register.
I programmed it in C... the code that scrolls the LEDs is there too(above) but i cant display letters,which is my goal. Does someone know something? ill appreciate
isp attiny2313
m8 you can buy the acr dragon it is like $50...
and do program and emulation..
attiny45 parallel programmer
Yeah.. I had the same problem.. can anyone solve this..?
this project was created by Tuomas tuononen..
Please help me
ATTINY2313 fuse settings
Thank you
  • HC912.rar
  • HC912 Sch.pdf
