[SOLVED] ATMega32 and 16*2 LCD
yviswanathbe
Full Member level 4
I am doing LCD interfacing with AtMega32 Micro controller.
Just for testing i am sending one character in the main function while loop.But the character is priniting at first row second column. Even if i give the command first row, first column also same is happening.
I have tried this in PROTEUS software,but the result is same.
I have attached PROTEUS file and the source code.
can some body suggest me where i am doing wrong.
Thanks and Regards,
Viswanath
  • atmega32V1.rar
Here is the code:
#include <mega32.h>
#include <delay.h>
#include<stdio.h>
typedef unsigned char bit_8;
                              LCD Port Configuration
#define LCD_PORT    PORTD
#define rs          PORTB.0
#define rw          PORTB.1
#define en          PORTB.2
#define flag        PIND.7
#define led         PORTB.1
          LCD Command MACROS
#define LCD_CLEAR             0x01
#define RETURN_HOME           0X02
#define DEC_CURSOR            0x04
#define INC_CURSOR            0x06
#define DISP_OFF_CUR_OFF      0x08
#define DISP_OFF_CUR_ON       0x0A
#define DISP_ON_CUR_OFF       0x0C
#define DISP_ON_CUR_BLINK     0x0E
#define SHIFT_CUR_LEFT        0x10
#define SHIFT_CUR_RIGHT       0x14
#define SHIFT_DISP_LEFT       0x18
#define SHIFT_DISP_RIGHT      0x1C
                    Function Prototypes
void lcd_init(void);                    // Initialize LCD
void busy(void);                              // Check Busy
void wrt_cmd(bit_8);                    // Sending Command
void wrt_data(bit_8);                    // Sending single character
void wrt_string(bit_8 *);          // Sending String
void wrt_value(bit_8);                    // Sending 8-bit Decimal value
void cursorxy(bit_8,bit_8);          // Bringing Cursor to (X,Y) location X -> 1,2 and Y -> 1-16
unsigned char *flash buf="Hello";
void lcd_init(void)
      wrt_cmd(0x38);
      wrt_cmd(0x06);
      wrt_cmd(0x08);
      wrt_cmd(0x01);
      wrt_cmd(0x0F);
      wrt_cmd(0x02);
**** Cheacking the busy flag of LCD
void busy()
         // delay_ms(1000);
          //flag=1;
          PORTD=0x00;
          DDRD=0x00;
          rs=0;
          rw=1;
          led=1;
          while(flag!=0)
                    en=0;
                    delay_ms(2);
                    en=1;
          led=0;
          PORTD=0xFF;
          DDRD=0xFF;
          Writing command to LCD
void wrt_cmd(bit_8 val)
          busy();
          LCD_PORT=val;
          rs=0;
          rw=0;
          en=1;
          delay_ms(2);
          en=0;
          Writing string to LCD
void wrt_string(char *string)
          busy();
          while(*string)
                    wrt_data(*string++);
          Writing data to LCD
void wrt_data(bit_8 ch)
          busy();
          LCD_PORT = ch;
          rs=1;
          rw=0;
          en=1;
          delay_ms(2);
          en=0;
          Writing 8-bit Value to LCD
void wrt_value(bit_8 x)
          bit_8 temp;
          temp = x/0x10;
          if(temp>9)
                    return;
          else
                    wrt_data(temp+0x30);
          temp = x%0x10;
          if(temp>9)
                    return;
          else
          Bringing Cursor to (X,Y) location of LCD
                    X -> 1,2
                    Y -> 1,16
void cursorxy(bit_8 x, bit_8 y)
          if((x<1||x>2)&&(y<1||y>16))
                    x=1;
                    y=1;
          if(x == 1)
                    wrt_cmd(0x7F+y);
          else
                    wrt_cmd(0xBF+y);
void main()
          PORTB=0x00;
          DDRB=0x07;
          //PORTD=0x00;
          //DDRD=0x00;
          delay_ms(20);
          lcd_init();
          while(1)
          delay_ms(1000);
          cursorxy(1,1);
          //wrt_cmd(0x80);
          //delay_ms(100);
          //buf="Hello";
          //wrt_string(buf);
          //delay_ms(100);
          //wrt_cmd(0xC0);
          //delay_ms(100);
          wrt_data('A');
          //delay_ms(100);
          delay_ms(1000);
Problem is, when you were defining RS, RW, etc, you defined RS as PORTB.0 but you also define led as PORTB.0 . So, when you are checking if the LCD is busy or not, you sent signals to RS. I changed LED to PORTB.1 and it's okay now.
Hope this helps.
Tahmid.
Hi Tahmid,
Thanks you very much.
Its working now.
Thanks and Regards,
Viswanath
---------- Post added at 10:55 ---------- Previous post was at 10:45 ----------
HI Tahmid,
One more question.
I am facing problem with write string function.
busy();
while(*string)
if i give wrt_string("HELLO"); in the main loop i am getting the following error
"function argument #1 of type 'flash unsigned char * *' is incompatible with required parameter of type 'bit_8 *'"
and is working only when i declare a variable as unsigned char *flash buf="Hello"; and passing this parameter in to the wrt_string function.
what could be the reason for compilation error? (I am using codevision avr.)
Regards,
Viswanath
I think you wrote
wrt_string('HELLO');
This shows error.
But if I write
This is fine and does not show any error.
I used this and it simulates fine.
#include <mega32.h>
#include <delay.h>
#include<stdio.h>
#define rs          PORTB.0
#define rw          PORTB.1
#define en          PORTB.2
#define flag        PIND.7
#define led         PORTB.1
          LCD Command MACROS
                    Function Prototypes
void lcd_init(void)
      wrt_cmd(0x38);
      wrt_cmd(0x06);
      wrt_cmd(0x08);
      wrt_cmd(0x01);
      wrt_cmd(0x0F);
      wrt_cmd(0x02);
void busy()
         // delay_ms(1000);
          //flag=1;
          PORTD=0x00;
          DDRD=0x00;
          rs=0;
          rw=1;
          led=1;
          while(flag!=0)
                    en=0;
                    delay_ms(2);
                    en=1;
          led=0;
          PORTD=0xFF;
          DDRD=0xFF;
          busy();
          LCD_PORT=val;
          rs=0;
          rw=0;
          en=1;
          delay_ms(2);
          en=0;
          busy();
          while(*string)
          Writing data to LCD
          busy();
          LCD_PORT = ch;
          rs=1;
          rw=0;
          en=1;
          delay_ms(2);
          en=0;
          bit_8 temp;
          temp = x/0x10;
          if(temp>9)
                    return;
          else
          temp = x%0x10;
          if(temp>9)
                    return;
          else
                    X -> 1,2
                    Y -> 1,16
                    x=1;
                    y=1;
          if(x == 1)
                    wrt_cmd(0x7F+y);
          else
                    wrt_cmd(0xBF+y);
void main()
          PORTB=0x00;
          DDRB=0x07;
          //PORTD=0x00;
          //DDRD=0x00;
          delay_ms(20);
          lcd_init();
          while(1)
          delay_ms(1000);
          cursorxy(1,1);
          //wrt_cmd(0x80);
          //delay_ms(100);
          //buf="Hello";
          //wrt_string(buf);
          //delay_ms(100);
          //wrt_cmd(0xC0);
          //delay_ms(100);
          wrt_data('A');
          cursorxy(1,3);
          //delay_ms(100);
          delay_ms(1000);
Hope this helps.
Tahmid.
Hi Tahmid,
I did same as you did.
I am still getting the error.
Which version are you using?
I am using Code Vision AVR 2.03.
is the problem with my code vision avr?
Thanks and Regards,
Viswanath
---------- Post added at 11:41 ---------- Previous post was at 11:35 ----------
Hi Tahmid,
Now it is working fine.
I have uninstalled and re installed the software.
Thanks for your time.
Regards,
Viswanath
