Atmega2560 problem with UART communication
Thiliniv
Junior Member level 3
I wrote a code for communication with Atmega2560 and a PC. My program is when the microcontroller ransmit a character
(say 65) it should be read using hyperterminal.
But in hyperterminal i just get some garbage characters. pls help me.
well the thing is you should transfer ascii values , but when you transmit 65 from controller you actually transmit 65 in hex , but the hyperterminal reads it as ascii and prints the ascii charater for it , another problem may be of improper baud rate ...
Hey Thiliniv... I will help you step by step. :)
step 1:
In this eksampel i will use the my own Atmega2560 development board - with a 16 MHZ crystal... i I hope That this will help you :)
(THIS IS MY AVR DEVELOPMENTBOARD WITH THE ATMEGA2560 plucked in )
(THIS MUST BE WHAT YOU GET WHEN YOU ARE USING UART... RIGHT ;) )
The reason why you get garbage characters is the internal-clock :/ we have to change it :)
(IN THIS PIC YOU CAN SEE THE ATMEGA2560 DEFAULT INTERNAL-CLOCK SETTINGS)
Step 2:
Now we are going to change the Internal-clock on the Atmega2560 :)
Im using AVR studio 4 :)
( CHANGE IT TO what you can see on the pic :) )
Step 3:
And after you have done that :)
(AND NOW IS SHOULD ALL WORK FINE)
Hope this helped :)
Rune Hansen
RuneHansen,
What you are telling is also correct , i think. Thanx for replying.
I solved the problem by unticking the "CKDIV8" fuse bit. I was using the internal oscillator of the micro controller which is 8MHz. When "CKDIV8" is programmed it is divided by 8. But when i untik it i culd get 8MHz again.
Good to hear :) if u have any other problems with the atmega2560.. just ask :)
---------- Post added at 17:40 ---------- Previous post was at 17:38 ----------
And take a look at my profile. in my album i have some pic of my new atmega2560 developmentboard if your are interestet?
