Assembly code solution needed!!
It's a very simple flow chart, you don't have to understand it, just draw the appropriate box shapes and join them with lines and arrows.
I missed the class last year, so, it's really troublesome understanding the concepts. Anyways, thanks, Brian!
I hope you understand what the code is doing.
Edit: There is a mistake in flowchart. I will upload the new one.
PHP:
;initialization of regiaters
Immidiate value 0x01 is loaded into register R2
Immidiate value 0xF0 is loaded into register R3
;main code starts from here
register R0 is loaded with 0x81
registers R2 is ANDed with R2 and result stored in R2	; 0x01 AND 0x01 = 0x01
If result of previous operation was 0 then jump to label xyz else continue
;continue code
	load register R0 with 0x82
	registers R0 and R3 are ANDed and result stored in R0
	unconditional jump to label wzp
;xyz code
		register R0 and R3 are ORed and result stored in R0
;wzp code	contents of register R0 is stored at address 0x82
		unconditional jump to start of main code
