ISPN
Newbie level 6
I interface GPS module with At89c2051 micro controller and i was able to isolate GPRMC data. However, i just wanted to process further latitude, logitude etc. After modifying the code, again i received other data formats (GPVTG) without processing the data.
I want to print the data in second line. So i made the LCD command for that. (However, its in wrong place.)
Basically i want to extract the data as latitude etc. If you possible could you please go through my codes and let me know the problem...
Thanking you.
Thanking you.
