jenko
Junior Member level 1
hi guys im stuying electriconic principles in school can anyone give me some pointers on how to:
1. a capacitor is connected across a 100v supply find the energy and charge if its value is 20uF
this is what i found : W=1/2(vxc)
100x0.020=2
2x1/2=1 watt
is this correct what have i found the charge or the energy :?: how do i find the other one
:?:![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
2. i have been asked to find the 3rd value of a capacitor in series which will give the capacitence of 3 µf the two values are 10µf and 15µf
(no idea)
3. 3 capacitors in series 5µf 10µf 15µf across a 100v supply find the equivitiant capacity, the charge and voltage of each capacitor?
(no idea)
4. circuit has the capacitence of 30µf it is reduced to 10µf what value capacitor is required and how would you connect it ?
(not a clue again)
5. 3 capacitors 10 15 25µf in parallel across 120v calculate the equiviliant charge and capacitence of each capacitor?
(im ashamed of myself now)![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
6. present chare on 3 capacitors connected in parelle across a 50v supply 80 500 1400 whats the value of the capacitors and the equiviliant capacitence of the combination![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
7. the flux density between two curcular plates each radius of 200mm is 10µf what is the charge of the plates
8.a metal sphere insulated from earth carries a charge 0.25µC. the radius of the sphere is 150mm what is the feild strength at the surface of the sphere
is this the write equation= 4(TL = Pie)= 3.142 R²
9. what is the charge on a 8µf capacitor when the v is 250v?
10. capacitor carries a charge of 100µC when 100v is applied what is the capacitence ?
:|![Crying :cry: :cry:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
IM REALY SORRY FOR THIS THREAD I HAVE LOOKED ON THE INTERNET AND COULDNT FIND MUCH CAN ANYONE GIVE ME LINKS TO WEBSITES THAT MAY HELP ME OR GIVE ME SOME INFOMATION ON THESE QUESTIONS I WOULD BE VERY GRATEFUL![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
BIG THANK YOU JENKO!
100x0.020=2
2x1/2=1 watt
(no idea)
(no idea)
(not a clue again)
