Roger Freeman
Junior Member level 2
Hello All
I'm loosely familiar with the notion of scaling e.g. an antenna at one particular wavelength can be scaled to a new frequency my multiplying all the dimensions by the ratio of new: old lambda. So for example a dipole ends up half as long at twice the frequency - and wire diameter would also half:
https://www.antennex.com/w4rnl/col0107/amod107.htm
But what about something like a helical - do I similarly just scale the helix length and helix diameter and number of turns on it (and the conductor diameter too)? Or is it the case that I scale the length of wire wrapped up into the helix and then wind that new length onto a new helical former (whose length and diameter is scaled), adjusting pitch to suit?
In the former case the length of wire would change by (scale factor)^2 which suggests the scaling should be based on conductor length.
Please can someone help me clear up my confusion? Thanks!
