Serginho
Newbie level 1
Hi all;
I am working with AMS H18, it is same with IBM HV 7SF. In the floating gates DRC (Antenna Rule) check, I get the following error message:
"Gates over RXHV touching MT touching FT/FTBAR must be tied down by MT metal."
First what is the meaning of tie down?
Second how can I achieve to tie down gates by MT metal?
Third, when I use an MIM cap which is not conneted to ground or sub, is this a problem about floating gates (antenna) rules?
Thanks in advance.
Thanks in advance.
