daisyzari
Junior Member level 3
We would just want to ask the need of the hookup of the signals from the package to the signals of the interface.
This is the code
I know this is sort of a beginners question and I think I can understand it a bit but we just need further explanations regarding the matter(or a professionals help regarding the matter.
Thank you:-D
This is the code
package I2C is
component simple_i2c is
port (
clk : in std_logic;
ena : in std_logic;
nReset : in std_logic;
clk_cnt : in unsigned(7 downto 0); -- 4x SCL
-- input signals
start,
stop,
read,
write,
ack_in : std_logic;
Din : in std_logic_vector(7 downto 0);
-- output signals
cmd_ack : out std_logic;
ack_out : out std_logic;
Dout : out std_logic_vector(7 downto 0);
-- i2c signals
SCL : inout std_logic;
SDA : inout std_logic
end component simple_i2c;
end package I2C;
-- State machine for reading data from Dallas 1621
-- Testsystem for i2c controller
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use work.i2c.all;
entity DS1621_interface is
port (
clk : in std_logic;
Dout : out std_logic_vector(7 downto 0); -- data read from ds1621
error : out std_logic; -- no correct ack received
end entity DS1621_interface;
architecture structural of DS1621_interface is
constant SLAVE_ADDR : std_logic_vector(6 downto 0) := "1001000";
constant CLK_CNT : unsigned(7 downto 0) := conv_unsigned(20, 8);
signal cmd_ack : std_logic;
signal D : std_logic_vector(7 downto 0);
signal lack, store_dout : std_logic;
signal start, read, write, ack, stop : std_logic;
signal i2c_dout : std_logic_vector(7 downto 0);
begin
-- hookup I2C controller
u1: simple_i2c port map (clk => clk, ena => '1', clk_cnt => clk_cnt, nReset => nReset,
read => read, write => write, start => start, stop => stop, ack_in => ack, cmd_ack => cmd_ack,
Din => D, Dout => i2c_dout, ack_out => lack, SCL => SCL, SDA => SDA);
Thank you:-D
