Enrique15
Member level 3
ic555
Hi again fellows.
Because the first project I built myself was using an IC 555, and I like to understand “mathematically” everything I use in a circuit, I started now to analyze mathematically its inner circuit.
So I started to check again my Donald Neaman’s electronics analysis text book. :lol:
The IC 555 inner circuit is as follows:
(image taken from the web: **broken link removed**)
By the way, this website has a great general explanation of the IC555 and some circuits.
I’ve re-drawn the circuit for a little bit more understanding:
At the beginning I start the analysis with just two connections: Vcc and Ground (the other pins of the IC 555 aren’t connected to anything for now).
First I analyze the most left-hand part of the circuit:
It seems that there are two current mirrors, but the left one doesn’t have a path for the “reference” current to flow, because the Darlington transistors aren’t active (they are cut) since there’s no voltage at the Threshold pin.
Therefore, eliminating the transistors that don’t have current flowing, the circuit is:
Now, theoretical current mirrors have a “normal” path for the reference current (normally a resistor), so we can obtain easily the reference current. But in this case the path for the reference current is the Darlington transistors. And that Darlington depends on the voltage at its entrance. It seems that the analysis for this current mirror is a bit different than the analysis I get in the textbook.
So, let’s analyze the Darlington biasing:
Calculating the Thevenin voltage and resistor:
This yield:
And solving we have:
We know that:
and also:
Besides:
and also: **broken link removed**
And because we have:
then:**broken link removed**
Assuming that:
yields: **broken link removed**
Solving the circuit:
Now we can move on to the current mirror:
where you see:
This results in:
and finally:
Sadly this is where I get stuck ; because I don’t figure out how to calculate currents through Q3 and Q4.
I could think of trying to make an analysis as in the Widlar current source, because of the resistors connected to the emitters of Q3 and Q4. But unfortunately at the end I’ll still have two variables: Ic3 and Ic4.
Maybe someone would say: “do not consider Ib3 and Ib4 and just make Ic4 = Ic1 + Ic2.”
But I think that in this case I just can’t try not considering both base currents. Because they will be totally different due to the two values of resistor connected to each emitter.
I thought of calculating the “reference” current (the one through Q4) by calculating the voltage drops through "R=4.7k" --> "Vbe4" --> "Vce2" --> "R=10k". But there’s the problem of not knowing Vce2 (and I don’t want to assume Vce2 = 0, because that won’t be accurate).
Can somebody suggest me a way of analyzing this one?
So I can move on analyzing the rest of the circuit.
Thanks in advance.
See you later.
Hi again fellows.
This yield:
We know that:
and also:
Besides:
Assuming that:
where you see:
This results in:
and finally:
Thanks in advance.
See you later.
