afr123
Junior Member level 1
I want to select analog switch for my circuit design with the following requirements:
I want to give differential signals as input to the switch whose common mode voltage is 1.65V and the voltage swing is 0 to 3.3V w.r.t ground. So, if one signal is at 3.3V, the other is at 0V w.r.t ground. Now, I guess that I will be able to use single supply analog switch (5V supply voltage) instead of dual supply +-5V.
Am I correct?
Thank you.
Am I correct?
Thank you.
