ALU (arithmetic logic unit) design in schematic & in ver
mrthn
Newbie level 2
turkey
i'm sorry the pictures arent seen.maybe you want to see pictures.you can visit: **broken link removed**
These codes are included everything what you need in ALU as a beginner. I compiled the codes in ISE Xilinx and I embedded the codes Spartan 3 FPGA. Everything is OK. I will give the schematic images. If you want , you can send a pm and I can give you the compiled program. Zero, overflow, less are also included.
This figure shows 32 bit ALU with 5 functions, most significant bit and 32 bit completed ALU without Zero output.
This figure shows zero output with 5 functions.
This figure shows 32 bit ALU with 6 functions with less and zero.
Verilog codes
Carry look ahead:
module carrybit(
input [30:0] ag,
input [30:0] bg,
input ai,
input bi,
input c0,
output [31:1] c
wire [30:0] a,b,g,p;
assign a=(ai)?~ag:ag;
assign b=(bi)?~bg:bg;
assign g[30:0]=a[30:0] & b[30:0];
assign p[30:0]=a[30:0] ^ b[30:0];
assign c[1]=g[0] | (p[0] & c0);
assign c[2]=g[1] | (p[1] & (g[0] | (p[0] & c0)));
assign c[3]=g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))));
assign c[4]=g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))));
assign c[5]=g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))));
assign c[6]=g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))));
assign c[7]=g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))));
assign c[8]=g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))));
assign c[9]=g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))));
assign c[10]=g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))));
assign c[11]=g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))));
assign c[12]=g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))));
assign c[13]=g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))));
assign c[14]=g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))));
assign c[15]=g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))));
assign c[16]=g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))));
assign c[17]=g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))));
assign c[18]=g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))));
assign c[19]=g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))));
assign c[20]=g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))));
assign c[21]=g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))));
assign c[22]=g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))));
assign c[23]=g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))));
assign c[24]=g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))));
assign c[25]=g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))));
assign c[26]=g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))))));
assign c[27]=g[26] | (p[26] & (g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))))))));
assign c[28]=g[27] | (p[27] & (g[27] | (p[27] & (g[26] | (p[26] & (g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))))))))))));
assign c[29]=g[28] | (p[28] & (g[27] | (p[27] & (g[27] | (p[27] & (g[26] | (p[26] & (g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))))))))))))));
assign c[30]=g[29] | (p[29] & (g[28] | (p[28] & (g[27] | (p[27] & (g[27] | (p[27] & (g[26] | (p[26] & (g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0)))))))))))))))))))))))))))))))))))))))))))))))))))))))))))));
assign c[31]=g[30] | (p[30] & (g[29] | (p[29] & g[28] | (p[28] & (g[27] | (p[27] & (g[27] | (p[27] & (g[26] | (p[26] & (g[25] | (p[25] & (g[24] | (p[24] & (g[23] | (p[23] & (g[22] | (p[22] & (g[21] | (p[21] & (g[20] | (p[20] & (g[19] | (p[19] & (g[18] | (p[18] & (g[17] | (p[17] & (g[16] | (p[16] & (g[15] | (p[15] & (g[14] | (p[14] & (g[13] | (p[13] & (g[12] | (p[12] & (g[11] | (p[11] & (g[10] | (p[10] & (g[9] | (p[9] & (g[8] | (p[8] & (g[7] | (p[7] & (g[6] | (p[6] & (g[5] | (p[5] & (g[4] | (p[4] & (g[3] | (p[3] & (g[2] | (p[2] & (g[1] | (p[1] & (g[0] | (p[0] & c0))))))))))))))))))))))))))))))))))))))))))))))))))))))))))))));
endmodule
Multiplexer:
module mux4×1(
input a,
input b,
input c,
input d,
input s1,
input s0,
output y
wire s1d,s0d,ak,bk,ck,dk;
not (s1d,s1);
not (s0d,s0);
and (ak,s1d,s0d,a);
and (bk,s1d,s0,b);
and (ck,s1,s0d,c);
and (dk,s1,s0,d);
or (y,ak,bk,ck,dk);
endmodule
ALU1 bit:
module Alu(
input a,
input b,
input c,
input less,
input [3:0] operant,
output result
wire ak,bk,xab,ve,veya,toplam;
xor(ak,a,operant[3]);
xor(bk,b,operant[2]);
and(ve,ak,bk);
or(veya,ak,bk);
xor (xab,ak,bk);
xor (toplam,xab,c);
mux4×1 m(ve,veya,toplam,less,operant[1],operant[0],result);
endmodule
ALU significant bit:
module Alulast(
input a,
input b,
input c,
input less,
output sonuc,
output toplam,
output overflow
wire ak,bk,xab,ve,veya;
and(ve,ak,bk);
or(veya,ak,bk);
xor(xab,ak,bk);
xor(toplam,xab,c);
everflow t(a,b,toplam,overflow);
mux4×1 m(ve,veya,toplam,less,operant[1],operant[0],sonuc);
endmodule
ALU 32 bit
module Alu32(
input [31:0] a,
input [31:0] b,
output [31:0] s,
output zero
wire[31:1]c;
wire tplm,overflow;
carrybit e(a[30:0],b[30:0],operant[3],operant[2],operant[2],c);
Alu a00(a[0],b[0],operant[2],tplm,operant,s[0]),
a01(a[1],b[1],c[1],1′b0,operant,s[1]),
a02(a[2],b[2],c[2],1′b0,operant,s[2]),
a03(a[3],b[3],c[3],1′b0,operant,s[3]),
a04(a[4],b[4],c[4],1′b0,operant,s[4]),
a05(a[5],b[5],c[5],1′b0,operant,s[5]),
a06(a[6],b[6],c[6],1′b0,operant,s[6]),
a07(a[7],b[7],c[7],1′b0,operant,s[7]),
a08(a[8],b[8],c[8],1′b0,operant,s[8]),
a09(a[9],b[9],c[9],1′b0,operant,s[9]),
a10(a[10],b[10],c[10],1′b0,operant,s[10]),
a11(a[11],b[11],c[11],1′b0,operant,s[11]),
a12(a[12],b[12],c[12],1′b0,operant,s[12]),
a13(a[13],b[13],c[13],1′b0,operant,s[13]),
a14(a[14],b[14],c[14],1′b0,operant,s[14]),
a15(a[15],b[15],c[15],1′b0,operant,s[15]),
a16(a[16],b[16],c[16],1′b0,operant,s[16]),
a17(a[17],b[17],c[17],1′b0,operant,s[17]),
a18(a[18],b[18],c[18],1′b0,operant,s[18]),
a19(a[19],b[19],c[19],1′b0,operant,s[19]),
a20(a[20],b[10],c[20],1′b0,operant,s[20]),
a21(a[21],b[21],c[21],1′b0,operant,s[21]),
a22(a[22],b[22],c[22],1′b0,operant,s[22]),
a23(a[23],b[23],c[23],1′b0,operant,s[23]),
a24(a[24],b[24],c[24],1′b0,operant,s[24]),
a25(a[25],b[25],c[25],1′b0,operant,s[25]),
a26(a[26],b[26],c[26],1′b0,operant,s[26]),
a27(a[27],b[27],c[27],1′b0,operant,s[27]),
a28(a[28],b[28],c[28],1′b0,operant,s[28]),
a29(a[29],b[29],c[29],1′b0,operant,s[29]),
a30(a[30],b[30],c[30],1′b0,operant,s[30]);
Alulast a31(a[31],b[31],c[31],1′b0,operant,s[31],tplm,overflow);
assign zero=~(|s[31:0]);
endmodule
Wow, way to go overboard there on the RTL :p
It would be great if you post comments in your code if you want others to learn from it. Its pretty useless for a beginner without comments. I can also guarantee that if you look back at your own code 2 months from now, you wont easily understand it.
Re: ALU (arithmetic logic unit) design in schematic & in
yes you are rigth.i will restore my post soon. i will add the commens line by line:) thank you.
for now if you dont understand a part of this code,you can ask. it was hard to write this:)
