Agilent upconverting with harmonic mixing
elektr0
Full Member level 5
Agilent Upconverter
Hello,
on page 3 of
Agilent says the frequency bands
250...500MHz is upconverted with harmonic mixing at 1/16.
What does it mean ?
For the higher frequency bands, it reads:
3...10 GHz at harmonic mixing = 1 (first LO harmonic)
10...20 GHz at harmonic mixing = 2 (second LO harmonic)
Thanks
Agilent Upconverter
Covering the frequency range from 250 kHz to 20 GHz is not easy task with simple LO.
In my view, Agilent using two synthesizers one upto 250MHz and other after 250MHz.
So for this range LO needs to be sized by the sclae factor 1/16, Similarly for the double of frequency range i.e. 500MHz to 1G it will be multiplied by two i.e. 1/8.
If you still need confirmation best way is to talk with Agilent technical people.
