Advise on PIR Sensor's circuit (Re-triggering problem)
financecatalyst
Newbie level 6
London
Hi, I have got some PIR sensors (RE200B) with BISS0001 PIR ICs. I have build the circuit as per the datasheet of BISS0001 IC. I am facing a weird problem on my breadboard where I have made this circuit which is that this circuit is very moody. It works fine sometimes, i.e. only triggers as expected, BUT sometimes it goes crazy and keeps re-triggering itself even if no external influence is there which could trigger the sensor.
Can someone advise if the circuit in the datasheet is appropriate or some modification is needed at the amplification stage?
As always Thanks in Advance.
But, what's the schematic you have implemented?
