goldriver
Junior Member level 2
I am designing a system which has sensors monitoring moisture,temperature and light and then it uses these parameters to control a motor. However,before implementation, i would like to carry out a simulation which provides simulation using ARDUINO MICROCONTROLLER as the coding is easier. Can you advise a software that would allow me to simulate a motor? . I know that sensors can be simulated using potentiometers or varible resistances as all of the above mentioned sensors convert the input to resistance change. The only issue is to simulate a motor. Is proteus advisable?
So to sum it up:
Please advise a simulation software which can allow me to achieve the above tasks using arduino such that i can upload an .ino file to the simulator.
So to sum it up:
