Buriedcode
Full Member level 6
Hi peeps,
I've been searching the net for a while now, and I'm probably missing something obvious, but I thought I might as well ask you guys....
What kind of adhesive is 'clear setting'? I'm trying to 'bond' an led into some clear acrylic, in the hope that the adhesive would essentially 'get rid' of the lens of the LED package, to increase viewing angle, and allow all the light from the LED to enter it (reducing fresnel/instertion loss).
I know that there are special acrylic cemets for bonding acrylic together, that sets perfectly clear, and forms a perfect join (after all, the cemet melts, and drys AS acrylic). I was thinking about good 'ol 2-part epoxy resin. But I have limited experience with it, and the only stuff I've worked with dried 'milky'. If anyone knows some easy-to-use stuff, that dries water-clear, and will bond the LED epoxy package to acrylic (or plexiglass) I would be grateful. Preferably so that the LED lens has no effect.
I realise this isn't exactly 'electronic' design, but I'm always impressed with the repsonses in this forum....experienced people are valued
Regards,
BuriedCode.
Regards,
BuriedCode.
