susane
Newbie level 6
Hello every one, i am an engineering student and i have been given a project, i want to communicate with ADS1292R with my Arduino UNO,
I have used the data sheet connections provided on page no 60.
i am using 4 wire SPI configuration, and for a good starting point, i just want to read a basic register with address 0x00, so i know that my communication is successful, but i am not able to do so,
Here is my code
If someone has experience with arduino and have done an SPI communication with this device, please help me
Here is my code
#include <SPI.h>
int ADS1292_DRDY_PIN = 6; /// Not used for now
int ADS1292_CS_PIN = 10; ////// Working
int ADS1292_START_PIN = 5; /// Working
int ADS1292_PWDN_PIN = 4;////// Working
int ADS1292_CLK_SEL = 3; /// Working
int dat2 = 0;
int dat1= 0;
int RegData1 = 0;
int RegData2 = 0;
int RegData3 = 0;
int RegData4 = 0;
int RegData5 = 0;
int RegData6 = 0;
void setup() {
pinMode(ADS1292_DRDY_PIN, INPUT); //6
pinMode(ADS1292_CS_PIN, OUTPUT); //10
pinMode(ADS1292_START_PIN, OUTPUT); //5
pinMode(ADS1292_PWDN_PIN, OUTPUT); //4
pinMode(ADS1292_CLK_SEL, OUTPUT); //3
//////////// Power up sequence////////////
delay(10);
digitalWrite(ADS1292_PWDN_PIN, HIGH);
delay(9000);
digitalWrite(ADS1292_PWDN_PIN, LOW);
delay(100);
delay(1000);
///// Set CLKSEL to 1////////////
digitalWrite(ADS1292_CLK_SEL, LOW);
delay(100);
digitalWrite(ADS1292_CLK_SEL, HIGH);
delay(10);
/////// Setting start pin to LOW////////
digitalWrite(ADS1292_START_PIN, LOW);
delay(100);
SPI.begin();
SPI.beginTransaction(SPISettings(1000000,MSBFIRST,SPI_MODE1));
delay(1000); // Wait for SPI to begin
Serial.begin(9600);
void loop() {
// Sending the first command to ADS for SDAC so registers can be written
digitalWrite(ADS1292_CS_PIN, LOW);
delayMicroseconds(5);
SPI.transfer(0b00000010); //// SPI Command for Wakeup
SPI.transfer(0b00010001); //// SPI Command to STOP read data continous mode
SPI.transfer(0b00100000); // Read register command
SPI.transfer(0b00000000); // Number of Registers to read
RegData1 = SPI.transfer(0b00000000);// Dummy Data
delayMicroseconds(1);
RegData2 = SPI.transfer(0b00000000);// Dummy Data
RegData3 = SPI.transfer(0b00000000);// Dummy Data
RegData4 = SPI.transfer(0b00000000);// Dummy Data
RegData5 = SPI.transfer(0b00000000);// Dummy Data
RegData6 = SPI.transfer(0b00000000);// Dummy Data
digitalWrite(ADS1292_CS_PIN, HIGH);
Serial.print(RegData1,HEX);
Serial.print("\t");
Serial.print(RegData2,HEX);
Serial.print("\t");
Serial.print(RegData3,HEX);
Serial.print("\t");
Serial.print(RegData4,HEX);
Serial.print("\t");
Serial.print(RegData5,HEX);
Serial.print("\t");
Serial.print(RegData6,HEX);
Serial.print("\n");
