sepehroo
Newbie level 1
Hey guys , please help me here, I'm so close to bang my face against the wall!
I'm trying to implement a very simple CPU using verilog. the datapath is attached to this post.
and here are my modules:
and finally the top module:
the problem is that when I'm trying to simulate it using the simulator tool, when assigning some value to data_bus it will be shown as some crossed line as if the value is HiZ there.
I'm a real newbie to verilog, please tell me how can assign values to my data_bus (which is an inout port)
PS: there is no memory unit yet, I will manually give values to data_bus
module tri_8bits(input_stream, control_signal, output_stream);
input [7:0] input_stream;
input control_signal;
output [7:0]output_stream;
assign output_stream = control_signal? input_stream: 8'bZZZZZZ;
endmodule
module tri_6bits(input_stream, control_signal, output_stream);
input [5:0] input_stream;
output [5:0]output_stream;
assign output_stream = control_signal? input_stream: 6'bZZZZZZ;
endmodule
module pc_holder(input_stream, ld, inc, clr, output_stream,clk,rst);
input ld,inc,clr,clk,rst;
output reg [5:0] output_stream;
always @(posedge(clk) or negedge(rst))
begin
if (rst==0)
output_stream=6'b00000000;
else if (clr==1)
else if (ld==1)
output_stream=input_stream;
else if (inc==1)
output_stream=input_stream+1;
end
endmodule
module alu(a, b, pass, add,q);
input [7:0] a;
input [5:0] b;
input pass,add;
output reg [7:0] q;
always @(pass or add) //vaghty shart barghar bood varede badane sho
begin
q=8'b00000000;
if (pass==1)
q=a;
else if (add==1)
q=a+b;
end
endmodule
module Dcontroller(opcode, rd_mem, wr_mem, ir_on_adr, pc_on_adr, dbus_on_data, data_on_dbus, ld_ir, ld_ac,
ld_pc, clr_pc,inc_pc, pass, alu_on_dbus, add,clk,rst);
input clk,rst;
input [0:1] opcode;
output reg rd_mem, wr_mem, ir_on_adr, pc_on_adr, dbus_on_data, data_on_dbus, ld_ir, ld_ac,
ld_pc,inc_pc, clr_pc, pass, alu_on_dbus, add;
parameter [1:0] reset=0, fetch=1, decode=2, execute=3;
reg [1:0] current;
begin
if (rst==0)begin
rd_mem <= 1'b0;
pc_on_adr <= 1'b0;
pass <= 1'b0;
ir_on_adr <= 1'b0;
wr_mem <= 1'b0;
ld_ac <= 1'b0;
dbus_on_data <= 1'b0;
data_on_dbus <= 1'b0;
ld_ir <= 1'b0;
alu_on_dbus <= 1'b0;
add <= 1'b0;
inc_pc <= 1'b0;
clr_pc <= 1'b0;
ld_pc <= 1'b0;
current<= reset;
end
else
case (current)
reset: begin
clr_pc<= 1'b1;
current<= fetch;
end
fetch: begin
pass <= 1'b0;
ir_on_adr <= 1'b0;
wr_mem <= 1'b0;
ld_ac <= 1'b0;
add <= 1'b0;
clr_pc <= 1'b0;
ld_pc <= 1'b0;
pc_on_adr<=1'b1;
rd_mem<=1'b1;
data_on_dbus<=1'b1;
ld_ir<=1'b1;
inc_pc<=1'b1;
current<= decode;
end
decode: begin
current<= execute;
end
execute: begin
ld_pc<=1'b1;
ir_on_adr<=1'b1;
dbus_on_data<=1'b1;
ld_ac<=1'b1;
alu_on_dbus<=1'b1;
wr_mem<=1'b1;
case (opcode)
2'b00:begin
ir_on_adr<=1'b1;
data_on_dbus<=1'b1;
ld_ac<=1'b1;
rd_mem<=1'b1;
end
2'b01:begin
wr_mem<=1'b1;
pass<=1'b1;
alu_on_dbus<=1'b1;
dbus_on_data<=1'b1;
ir_on_adr<=1'b1;
end
2'b10:begin
ld_pc<=1'b1;
end
2'b11:begin
add<=1'b1;
alu_on_dbus<=1'b1;
ld_ac<=1'b1;
data_on_dbus<=1'b0;
dbus_on_data<=1'b1;
end
endcase
current<= fetch;
end
endcase
end
endmodule
module my_registers8bit(input_stream, output_stream,clk, ld);
input clk;
input ld;
output reg [7:0] output_stream;
always @(posedge(clk))
begin
if (ld==1)
output_stream=input_stream; //nonblocking
end
endmodule
module IR(input_stream, clk, ld, opcode, output_stream);
input clk;
input ld;
output reg [1:0] opcode;
begin
if (ld==1)
begin
output_stream=input_stream[5:0];
opcode=input_stream[7:6];
end
end
endmodule
input clk;
input ld;
begin
if (ld==1)
end
endmodule
module project4(data_bus,clk,rst, addr_bus,rd_mem, wr_mem);
inout [7:0] data_bus;
output rd_mem, wr_mem;
wire [1:0]opcode;
output [5:0] addr_bus;
wire [7:0] dbus;
input clk,rst;
wire ld_ac, ld_ir, inc_pc,ld_pc,clr_pc, pass, add,data_on_bus,
dbus_on_data,alu_on_dbus, ir_on_add, pc_on_add;
wire [5:0] ir_output, pc_output;
wire [7:0] alu_output,ac_output ;
tri_8bits tri_A(data_bus, data_on_bus, dbus);
my_registers8bit AC(dbus, ac_output, clk, ld_ac);
IR my_ir (dbus, clk, ld_ir, opcode, ir_output);
Dcontroller controller(opcode, rd_mem, wr_mem, ir_on_add, pc_on_add, dbus_on_data, data_on_bus, ld_ir, ld_ac, ld_pc,
clr_pc,inc_pc, pass, alu_on_dbus, add, clk, rst);
pc_holder pc(ir_output, ld_pc, inc_pc, clr_pc, pc_output,clk,rst);
tri_6bits tri_E(pc_output, pc_on_add, addr_bus); //add this later
tri_6bits tri_D(ir_output, ir_on_add, addr_bus); //add this later
alu my_alu (ac_output, ir_output, pass, add, alu_output);
tri_8bits tri_C(alu_output, alu_on_dbus, dbus);
tri_8bits tri_B(dbus, dbus_on_data, data_bus);
endmodule
