A question on the power spilitter
chang830
Full Member level 5
power spilitter
I see some one used the attached circuit as a power splitter. It is ussd in a 900MHz RF system. I can not understand its principle. Would anyone pls. gives me some explainations on this circuit?
Thanks in advance
spilitter
Hi
You are sure that there was not any capacitors?
coupling may exist between L1 and L2. So the current flowing through L1 and L2 are same.
Hi
It is a lumped version of Wilkinson power divider. Instead of quarterwavelength lines inductors are used to provide 90 deg phase shift on the operating frequency. The divider can be very small as oposed to classical realization with transmission lines.
flyhigh
    chang830
flyhigh said:
Hi
flyhigh
Hi, flyhigh,
I think you are tight. Attached figure is the actuaral circuit I saw. Attached another PDF file is an article about the Wilkinson power splitters. I agree with you that it is the Wilkinson powet splitter. But just as tyassin asked above. Where is the capacitors Cp in the fiugre? I think the capacitos in the attached figure is the dc-blocking capacitor. So where is the Cp?
would u pls. shed some more light on it?
Thanks in advance
A lumped element Wilkinson splitter needs the capacitors as in the paper you posted, otherwise the isolation between divided ports is very poor.
A splitter is used not only to divide/combine signals, but also to isolate one from each other.
So, whoever designs the schematic you posted was a little bit “greedy” trying to get economy of parts.
    chang830
