A question about phase noise
walkingsun
Member level 2
Member level 2
CN
There is an buffered oscillator.
If the phase nosie of oscillator is -140dBc and the phase noise of buffer is -140dBc,
the total phase noise is -134dBc?
Thank you
But how to define the phase noise spec of a buffer?
good question and one I don't really know the answer to (it is complex for sure) -- and I probably shouldn't have thrown out a guess so quickly.
There are a number of papers from the IEEE-UFFC society that discuss additive phase noise from buffers and such. I would research there.
Lance
the phase nose after the buffer can estimated as the following:
L(fm)=(P_noise*G+KTB(NF-1)*G)/(P_IN*G)=
=L(fm)_in+(KTB(NF-1))/P_IN
P_IN---->THE INPUT POWER;
P_NOISE------>THE 1 HZ POWER fm offset from the FC
G---->GAIN of the buffer;
NF---->noise figure of the buffer
from the above equation, we totify that the KTB(NF-1) is very smaller than the Pin, so the buffer shall not affect the VCO phase noise;but y shall pay attention to the p_1dB point of the buffer, y shall not let the pin*g is greater than the p_1dB!
Very good question! Just to not start a new thread :
I plan to construct a very low phase noise vcxo but his level out it's arround 0dBm and my mixer stage needs +17dBm. Adding 3dB pad before mixer, I need +20dBm from vcxo.
The phase noise of vcxo itself it's arround -145dBm @ 100Hz so can I preserve this figure up to +20dBm ?
