Look for "electroluminescent driver" on google. Supertex has some driver for that, and a part of it is a step up converter used to generate high voltage. **broken link removed**
High voltage IC is normally very expensive, and maybe it is not available in your market.
So it is the best to design the ordinary preamplifier and then design the output stage by transistors for +/- 220V.
