bianchi77
- Joined
- Jun 11, 2009
- Messages
- 1,313
- Helped
- 21
- Reputation
- 44
- Reaction score
- 20
- Trophy points
- 1,318
- Location
- California
- Activity points
- 9,442
to make sure both HC154 don't work at the same time, please try this :
Code:sbit E1 at P3_0_bit; sbit E2 at P3_1_bit; void main() { unsigned char a; unsigned char x; unsigned char y; unsigned char z; code unsigned char font[88]= { // 0 1 2 3 4 5 6 7 8 9 10 0x3C,0x3C,0x84,0x81,0x10,0x8F,0x60,0x81,0x66,0x46,0x00, 0x42,0x00,0xC2,0x89,0x18,0x89,0x90,0x41,0x99,0x89,0x00, 0xA1,0x00,0xA1,0x89,0x14,0x89,0x98,0x21,0x99,0x89,0x00, 0x91,0xFF,0x91,0x89,0x12,0x89,0x94,0x11,0x99,0x89,0x00, 0x89,0xFF,0x91,0x89,0x11,0x89,0x92,0x09,0x99,0x89,0x00, 0x85,0x06,0x91,0x89,0x11,0x89,0x91,0x05,0x99,0x89,0x00, 0x42,0x04,0x89,0x49,0xFF,0x89,0x90,0x03,0x99,0x89,0x00, 0x3C,0x00,0x86,0x36,0x10,0x71,0x60,0x01,0x66,0x7E,0x00 }; unsigned char display [4] = {5,6,7,8}; do { for (z=0;z<100;z++) { for (x=0;x<2;x++) //2 characters { for (y=0;y<8;y++ ) //each character contains 8 cols. { a=(x*8)+y; // 8 cols P1=a; E1=0; E2=1; a=(y*11)+display[x]; P2 = font[a]; delay_us(500); }; }; }; for (z=0;z<100;z++) { for (x=2;x<4;x++) //2 characters { for (y=0;y<8;y++ ) //each character contains 8 cols. { a=(x*8)+y; // 8 cols P1=a; E1=1; E2=0; a=(y*11)+display[x]; P2 = font[a]; delay_us(500); }; }; }; } while(1); // Endless loop }
It will show :
1st and 2nd character will show 5 and 6 while 3rd and 4th are off.
then after about one second :
3rd and 4th character will show 7 and 8 while 1st and 2nd are off.
and please check the voltage at microcontroller port 3.0 and port3.1. Its should be a pulse.
hey, wait, Port 3.0 and 3.1? You don't use these pins for UART, do you? if you did, please use another pins.
Good idea mate,
Let me have a try.....
May be I will get the luck this time....
---------- Post added at 04:11 ---------- Previous post was at 03:21 ----------
It will show :
I didn't use P3.0 and P3.1 for UART, it's free, so far I can see in my code....
---------- Post added at 04:12 ---------- Previous post was at 04:11 ----------
It will show :
May be just change P3.0 and P3.1 to P3.2 and P3.3, but I don't think it will help....
---------- Post added at 05:46 ---------- Previous post was at 04:12 ----------
Mate,
It's not 5 6 7 8 but 5 6 and strange characters,
you can see on the video
