AD4 EQU 084H ; P0.4 LOW NIBBLE OF PORT 1 IS USED FOR DATA
AD5 EQU 085H ; P0.5 LOW NIBBLE OF PORT 1 IS USED FOR DATA
AD6 EQU 086H ; P0.6 LOW NIBBLE OF PORT 1 IS USED FOR DATA
AD7 EQU 087H ; P0.7 LOW NIBBLE OF PORT 1 IS USED FOR DATA
EN EQU 082H ; P0.2 LCD ENABLE LINE
RS EQU 080H ; P0.0 LCD REGISTER SELECT LINE
RW EQU 081H ; P0.1 LCD REGISTER SELECT LINE
?PR?lcd_asm?LCD_ASM SEGMENT CODE
PUBLIC Reset_LCD
PUBLIC init_lcd
PUBLIC LCD_write_command
PUBLIC LCD_write_text
; SUB WRITES A COMMAND WORD TO THE LCD
; COMMAND MUST BE PLACED IN R4 BY CALLING PROGRAM
MOV C, ACC.4 ; LOAD HIGH NIBBLE ON DATA BUS
MOV AD4, C ; ONE BIT AT A TIME USING...
MOV C, ACC.5 ; BIT MOVE OPERATOINS
MOV AD5, C
MOV C, ACC.6
MOV AD6, C
MOV C, ACC.7
MOV AD7, C
SETB EN ; PULSE THE ENABLE LINE
CLR EN
MOV C, ACC.0 ; SIMILARLY, LOAD LOW NIBBLE
MOV AD4, C
MOV C, ACC.1
MOV AD5, C
MOV C, ACC.2
MOV AD6, C
MOV C, ACC.3
MOV AD7, C
CLR EN
LCALL PULSEEWAIT4 ; PULSE THE ENABLE LINE...
; AND WAIT FOR BUSY FLAG TO CLEAR
lcall MDELAY
RET
; SUB TO WRITE A DATA WORD TO THE LCD
; DATA MUST BE PLACED IN R4 BY CALLING PROGRAM
LCD_write_text:
MOV LCD_var,A
CLR EN
SETB RS ; SELECT SEND DATA
CLR RW ; SELECT WRITE OPERATION
MOV A, LCD_var ; PUT DATA BYTE IN ACC
MOV AD5, C
MOV C, ACC.6
MOV AD6, C
MOV C, ACC.7
MOV AD7, C
CLR EN
MOV AD4, C
MOV C, ACC.1
MOV AD5, C
MOV C, ACC.2
MOV AD6, C
MOV C, ACC.3
MOV AD7, C
CLR EN
LCALL PULSEEWAIT41 ; PULSE THE ENABLE LINE...
lcall MDELAY
RET
PULSEEWAIT4:
clr EN
setb EN ; PULSE THE ENABLE LINE
clr EN
mov LCD_DATA, #0FH ; PREPARE PORT FOR INPUT
setb RW ; PREPARE R/W FOR READ OPERATION
mov A,#80h
orl A,RW
mov RW,A
mov dptr,#0c002h
movx @dptr,A
PEW:
setb EN ; START THE ENABLE PULSE
mov A, LCD_DATA ; READ STATUS NIBBLE
clr EN ; END ENABLE PULSE
setb EN ; PRETEND READING STATUS LOW NIBBLE
clr EN
JB ACC.7, PEW ; LOOP WHILE BUSY FLAG IS SET
ret
PULSEEWAIT41:
clr EN
clr EN
mov LCD_DATA, #2FH ; PREPARE PORT FOR INPUT
mov A,#80h
orl A,RW
mov dptr,#0c002h
movx @dptr,A
mov RW,A
PEW1:
clr EN
JB ACC.7, PEW1 ; LOOP WHILE BUSY FLAG IS SET
ret
END
;;;;;;;;;;;;;;;;;;;;;;;;;;end of code;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
