74HC390 but Quad, does it exist????
neazoi
Advanced Member level 6
Greece
Is there a quad version of the 74HC390?
How? Would need a 30 pin package. Why? Just use two.
You could use programmable logic as single chip solution. CPLD (Or older GAL, PAL...)
You could use a microcontroller as single chip solution.
You could use two HC390.
You coud use ICM7217 as 4 digit decimal counter with multiplexed BCD outputs (+ 7 segment LED display controller)
