[SOLVED] 3310 LCD interfacing with pic18f4620
sir bigdogguru,
its being clear now, as the image above, does the connection now from the pic to the pins of 3310 correct? hope its correct.
Yes, that would be a viable interface.
Is the Nokia 3310 part of your ZigBee project?
How is your project coming along by the way?
BigDog
yes! its correct, and thanks to you sir,yup its a big part of our project, ive decided to include the nokia 3310 for graphical interface. since LCD 16x2 is not available on any electronics shops here, and 3310 LCD is more cheaper than LCD 16x2 and way more available. so i think its a good idea. and for the zigbee, we havent keep in touch with it :(, since i want to complete something this week, as ive said were 2 weeks behind of completion and still no progress, so many difficulties to achieve and interface a successful program and availability of the components(especially money), hope that when our group touch already about zigbee, you can guide us sir.
... hope that when our group touch already about zigbee, you can guide us sir.
Absolutely. Just keep me posted.
Do you have any experience generating graphics on the Nokia 3310?
I found the is project which covers some interesting concepts concerning the graphics design and implementation:
3310 Nokia LCD & PIC 12f683
BigDog
Reactions: dabby21 and FvM
    FvM
    dabby21
anyone can help me to understand thoroughly about nokia 3310?datasheet of it can do.. and a schematic(with code would be great) interfacing pic18f4620 using PORTD.. ive read many post with same topic with mine but most of it uses pic16 and im a bit confuse of the 3310 schematic interface with pics. thanks..
there is a working example of Nokia 3310 LCD here with protues simulation..
sir bigdogguru,
can you check my program and simulation if its correct? i base the program with various links youve given me. and also the simulation. ive successfully build the program but no output. i think ive got a lot of errors on initializing or maybe in simulation. please help.
romel,
bro, thanks for the link, ill check that tommorow, im about to sleep(sakit na nang ulo e :) )
  • 3310.rar
The project you uploaded appears to be missing an ASM file. I'll attempt to rebuild the project from scratch.
BigDog
sir, we are permitted to use microC, and ive tried this program, example program in this site, there are errors in the library botskool, and i find it hard to debug it since its a library.. any idea sir?
you might want to try my link try to see it if you can easily interface it to your device.. you can just simply take out the lcd.c and lcd.h file
you can get it working for a few minutes..
---------- Post added at 08:51 ---------- Previous post was at 08:45 ----------
of you can post the error you are facing now..
sir romel,
i cant open the link you have given me,since im in school right now and using the wifi, our wifi network is dirty though,sorry :( but ill check it out when i got home
Hi Dabby21,
The code now compilers without errors or warnings, I zipped the project up. Make sure you check any important settings, clock frequency, etc.
BigDog
  • daddy21.zip
