[SOLVED] 3-D Radiation Pattern plot in HFSS
catalyst101
Hi everybody,
I'm simulating a microstrip antenna using hfss.when I plot the 3D polar plot it I get the results but its not a steady image (it flashes) I have to click on it several times to see it and sometimes I don't. Did this happen to any of you?any ideas ?
thnx
No, I have never seen that.
Are you using Linux? I noticed a few issues with HFSS on that, but then I have seen a few issues on Windows too. But not the one you describe. I've used HFSS 13 and 14.
Dave
Hi
NO, I use windows7
hfss 13.0
to create the report I set up the infinite sphere to default values. create far field report --->3D polar plot , specified frequency and "phi" "theta" to all
Gain --->Gain Total --->dB
what may I do or try?
thnx
Your method sounds right. I would suggest perhaps tweaking with options for your graphics card, the graphics properties windows uses, or if all else fails, change the graphics card.
Is this runing in a virtual machine? I've known VMs to cause some issues like you describe with some software.
Dave
Dave
Could you plz explain how to change the graphics card properties, I've never dealt with this.
NO,I'm not using a virtual machine. I'm using my own laptop.
Thank you.
Sometimes there are specific tools to change how your graphics card behaves - NVida cards have a lot.
Otherwise Go to Control Panel and search on "Adjust visual effects", then you get options to play with various things. You might find that helps. (This is where I find it on Windoze 7). Good luck.
Otherwise, ask might try asking Ansys or asking on a Windows forum.
Dave
I've attached pictures from windows7 control panel. Just to make sure I got it,are they the ones you indicated ?
Thank you, you've led me to something I can work on.
  • visual effects window.doc
I'm not sure why you bothered to create a word document to show a screen shot. Start -> all Programs -> Accessories -> Snipping tool
will let you save a a png file any part of the screen you want.
But basially what you have found is what I was suggesting might help. It may be that turning on or off some of these effects will solve your problem.
There may be other software produced by the manufacturer of the graphics card, which will allow you to change settings. That woud normally be installed when you buy a laptop. Nvidia cards in particular using have a ton of options you can change.
Turning off 3D acceleration might work. All these things are worth a try - I have no experience with this sort of problem with HFSS, so are just making educated guesses as to what might help
Dave.
Hi Dave,
I don't have snipping tool option in accessories.
Besides I didn't find the 3D acceleration option.
REGARDS
Hi Dave,
REGARDS
I see it in my system - Windows 7 Home Premium.
https://windows.microsoft.com/en-IE/windows7/products/features/snipping-tool
and I'm fairly sure it is in the Windows 7 Ultimate edition I have on another machine, which I rarely use.
I think whether you can enable/disable 3D really depends on your hardware. But there may be options in Windoze to enable 3D. I don't know, and it's not my favorite OS.
You might also check if you have the latest version of DirectX, OpenGL, Direct3D or whatever else HFSS uses.
Sorry, I don't know what HFSS supports, but it is documented. As to where you find the tools, you will just have to hunt or find someone who knows more about Windoze than me.
Dave
Hi everybody
My problem is solved. if you have a graphics card just choose the suitable graphics processor.(in my case Just right clicked on the desktop Graphics properties -> switchable graphics-> high performance.)
