Easy peasy
Advanced Member level 6
there would be a watt or two in the EI lams depending on the flux level you run at (N.B. quality CT's run at very low flux levels - hence their size)
That has been pretty much my experience with CTs as well.The CT saturated surprisingly early. After about 1 - 1.5 Amps, Increasing voltage simply increased primary current and the secondary current refused to increase much. I couldn't exceed 5 Amps primary current as this was the Max rating..
