catalyst101
Member level 1
Dear All,
I have good return loss when I draw the airbox lambda/4 away from the antenna BUT the problem is that the 2D radiation pattern isn't correct.
I've noticed that there is a relation between the airbox size and the radiation pattern and the labmda/4 airbox doesn't give good results. Is it supposed to use the same air box for both parameters or use different airboxes and if so what should its dimensions be?
this puzzled me for long.
Thanks in advance.
Thanks in advance.
