20V dc to 60V dc & 90 to 265V ac Xenon tube flasher circuit
grittinjames
Advanced Member level 1
bangalore india
Any one have simple solution for DC and AC Xenon tube flasher in same board?
Schematics or idea will be great help
Power and frequency matters for the design.
I presume you can find many mains voltage supplied flasher circuits on the internet. For DC input you'll obviously need a DC/DC converter, preferably of the flyback type to charge the storage capacitor.
Is there any way to club together? so that it operates for AC and DC , Can have two different connector fo AC or DC
What output do you want (voltage? @ power?, flashing frequency? at what sort of regulation?). Because of the very wide voltage input (20 - 265), the currents being used are also very wide, else you could do it all with one converter. If its relatively low power say < 100W you could concievablely do it in one go. Else you need two converter (at least).
Frank
Small xenon flash tubes have a voltage range of e.g. 250 to 600 V. The energy storage capacitor can be charged from mains voltage by a simple rectifier (possibly voltage doubling) through a series resistance or series capacitor. You can replace/supplement this power supply by a flyback DC/DC converter for DC operation.
There are many large & small ideas in google images.
The one problem with most of them is that they are also great cell phone jammers due to the intense E fields and resonance of sub-nanosecond avalanche effects in the wires. So follow good EMC design rules.
