$2 for PCB Prototype with JLCPCB
Mona0312
Newbie level 1
I ordered my PCBs from JLCPCB this week and am impressed with the quality. The price is $2 for 10pcs boards. 1.2mm thick, 1-OZ copper, 6/6-mil outer (0.1525mm).
The boards look great. The internal cutout is correct. Copper traces are perfect. Drills are centered perfect. Vias that I had tented & not-tented are correct. Silk (both sides) is spot on, 45-mil(1.14mm) high 6-mil(0.1524mm) wide text, very good looking.
From ORDER to PROCESSING to SHIPPED can be tracked.
3-day quick turnarounds and 3-day DHL delivery.
If you go to JLCPCB Prototype ordering page https://www.jlcpcb.com/quote, you will be greeted with a simple layout, you just need to drag&drop your gerber files and select the various options for the pcb panel. They let you select the quantity, pcb thickness, soldermask color, surface finish, copper weight, temp rating, holes/traces/spacing, pretty much standard options with every board house these days.
